Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
Remove the battery.
Remove the two 5mm screws securing the right side of the RAM cover to the computer frame.
Lift the right side of the RAM cover to remove.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Remove the two 3.0mm screws on the side of the laptop shown.
Remove the one 5.0mm screw in the hard drive compartment.
另外一个人完成了本指南。
