跳转到主内容
  1. Turn off and unplug the computer from all external power sources.
    • Turn off and unplug the computer from all external power sources.
    • Shut the screen, and lay the computer face-down on a flat, sturdy surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image. Sliding this switch from right to left will release the battery.
    • Remove the battery.
  2. Remove the two 5mm screws securing the right side of the RAM cover to the computer frame. Lift the right side of the RAM cover to remove. Lift the right side of the RAM cover to remove.
    • Remove the two 5mm screws securing the right side of the RAM cover to the computer frame.
    • Lift the right side of the RAM cover to remove.
  3. The wifi card is connected to the computer with the two antenna lead wires.
    • The wifi card is connected to the computer with the two antenna lead wires.
    • Note where the white AUX wire and the black MAIN wire connect to the wifi card before disconnecting.
  4. Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card. The white wire connects to the AUX terminal.
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  5. Remove the two 6.0mm screws securing the wifi card to the computer.
    • Remove the two 6.0mm screws securing the wifi card to the computer.
  6. Remove the wifi card.
    • Remove the wifi card.
  7. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  8. Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  9. Turn the computer over and open the screen. This provides access to the screen hinges.
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  10. Be careful not to bend the keyboard switch cover too far when removing it.
    • Be careful not to bend the keyboard switch cover too far when removing it.
  11. Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  12. Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors. Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  13. This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  14. This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lift the keyboard off the keyboard frame.
  15. Use the plastic prying tool to disconnect the screen cable from the system board. Use the plastic prying tool to disconnect the screen cable from the system board.
    • Use the plastic prying tool to disconnect the screen cable from the system board.
  16. Remove the four 7.0mm screws securing the screen to the computer. Remove the four 7.0mm screws securing the screen to the computer.
    • Remove the four 7.0mm screws securing the screen to the computer.
  17. Separate the screen from the computer frame by lifting the screen straight up. Disconnect the PCI wires by pulling them free of the computer.
    • Separate the screen from the computer frame by lifting the screen straight up.
    • Disconnect the PCI wires by pulling them free of the computer.
结论
2等其他人完成本指南。
Thanh Nguyen
于2010年10月05日注册
366 信誉积分
创作了2篇指南
团队
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G34
4 名成员
创作了11篇指南
To reinstall the PCI WIRES I'm finding no other way to reattach them except by removing the outer cover AND RE-ATTACHING. . I will finish-up the repair and send you my results
Christopher Rouse - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 19
总计 12,899
