跳转到主内容
HP Pavilion dv5000 RTC Battery Replacement
你所需要的
  1. HP Pavilion dv5000 RTC Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: 步骤 2 中的图像 1,3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: 步骤 2 中的图像 2,3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: 步骤 2 中的图像 3,3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: 步骤 3 中的图像 1,2 HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: 步骤 3 中的图像 2,2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 RTC Battery Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv5000 RTC Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  5. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: 步骤 5 中的图像 1,3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: 步骤 5 中的图像 2,3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: 步骤 5 中的图像 3,3
    • Remove the RTC Battery from the battery holder.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G34
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 11,905
