简介
This guide will tell you how to remove the optical drive, or CD/DVD drive.
工具
配件
没有特定配件。
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
另外一个人完成了本指南。
