跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv5000 Keyboard Replacement
你所需要的
  1. HP Pavilion dv5000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. HP Pavilion dv5000 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. HP Pavilion dv5000 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. HP Pavilion dv5000 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. HP Pavilion dv5000 Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv5000 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  7. HP Pavilion dv5000 Keyboard Replacement: 步骤 7 中的图像 1,1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. HP Pavilion dv5000 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard off the keyboard frame.
结论
6等其他人完成本指南。
Alex Kwok
于10/05/10注册
274 声望
创作了3篇指南
团队
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G34
4 名成员
创作了11篇指南
2指南评论
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - 回复 分享
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 56
总计 11,586
