当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn off the computer, and unplug it from all external power sources.
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Remove the two screws securing the hard drive cover.
Remove the hard drive cover.
The hard drive is now accessible.
Remove the two 5.0mm screws securing the hard drive bracket.
Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
Lift the hard drive out of the hard drive bay, left side first.
Remove the hard drive.
If you are replacing the hard drive, remove the four additional screws (two on each side) securing the metal shield to the hard drive. Then, remove the shield from the drive.
取消:我没有完成这个指南。
2等其他人完成本指南。
与10其他贡献者
于10/11/10注册
253 声望
创作了2篇指南
徽章: 10
+ 7更多徽章
CPSU-REGAN-F10S21G34
4 名成员
创作了11篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 22
总计 14,404
