跳转到主内容
HP Pavilion dv4000 Keyboard Replacement
你所需要的
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Have your device open in front of you for easy access to the keyboard.
  5. HP Pavilion dv4000 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
  6. HP Pavilion dv4000 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
  7. HP Pavilion dv4000 Keyboard Replacement: 步骤 7 中的图像 1,3 HP Pavilion dv4000 Keyboard Replacement: 步骤 7 中的图像 2,3 HP Pavilion dv4000 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
  8. HP Pavilion dv4000 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Locate the four 2x2 mm screws that hold the keyboard in place.
  9. HP Pavilion dv4000 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
  10. HP Pavilion dv4000 Keyboard Replacement: 步骤 10 中的图像 1,2 HP Pavilion dv4000 Keyboard Replacement: 步骤 10 中的图像 2,2
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
  11. HP Pavilion dv4000 Keyboard Replacement: 步骤 11 中的图像 1,1
    • Locate where the ribbon strip is connected to the motherboard.
  12. HP Pavilion dv4000 Keyboard Replacement: 步骤 12 中的图像 1,2 HP Pavilion dv4000 Keyboard Replacement: 步骤 12 中的图像 2,2
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
  13. HP Pavilion dv4000 Keyboard Replacement: 步骤 13 中的图像 1,3 HP Pavilion dv4000 Keyboard Replacement: 步骤 13 中的图像 2,3 HP Pavilion dv4000 Keyboard Replacement: 步骤 13 中的图像 3,3
    • Remove the keyboard.
结论
另外一个人完成了本指南。
Nick LaMarche
于10/18/16注册
373 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 892
