跳转到主内容
HP Pavilion dv4000 Hard Drive Replacement
你所需要的
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv4000 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
结论
To replace the hard drive, follow these instructions in reverse.
另外一个人完成了本指南。
Chris Marshall
于10/18/16注册
454 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 23
总计 1,829
