跳转到主内容
HP Pavilion dv4000 CD/DVD drive Replacement
你所需要的
  1. HP Pavilion dv4000 CD/DVD drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 3 中的图像 1,1
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 CD/DVD drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 6 中的图像 2,2
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 7 中的图像 1,1
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
  8. HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: 步骤 8 中的图像 1,2 HP Pavilion dv4000 CD/DVD drive Replacement, CD/DVD Drive: 步骤 8 中的图像 2,2
    • Locate the one 2x5 mm screw in the hard drive bay.
    • Unscrew the screw with a #00 Phillips screwdriver.
  9. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 9 中的图像 1,3 HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 9 中的图像 2,3 HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 9 中的图像 3,3
    • Locate the hole next to the DVD drive release button.
    • Insert a paperclip into the hole to release the DVD drive.
  10. HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 10 中的图像 1,2 HP Pavilion dv4000 CD/DVD drive Replacement: 步骤 10 中的图像 2,2
    • Carefully grasp the DVD drive and slide it out.
结论
4等其他人完成本指南。
Nick LaMarche
于10/18/16注册
373 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 的会员
UMASSD-CATANIA-F16S4G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 1,128
