跳转到主内容
HP Pavilion dv4-4141us Fan Replacement
你所需要的
  1. HP Pavilion dv4-4141us Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Lift up the back panel using a spudger, and remove it from the device.
  2. HP Pavilion dv4-4141us Fan Replacement: 步骤 2 中的图像 1,3 HP Pavilion dv4-4141us Fan Replacement: 步骤 2 中的图像 2,3 HP Pavilion dv4-4141us Fan Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #1 screwdriver unscrew the panel from the computer.
    • Lift the panel up and remove it from the laptop.
  3. HP Pavilion dv4-4141us Fan Replacement, Hard Drive: 步骤 3 中的图像 1,3 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: 步骤 3 中的图像 2,3 HP Pavilion dv4-4141us Fan Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Use the spudger to lift the left side of the hard drive.
    • Unplug the hard drive and remove it from the device.
  4. HP Pavilion dv4-4141us Fan Replacement, Fan: 步骤 4 中的图像 1,2 HP Pavilion dv4-4141us Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Use a Phillips #1 Screwdriver to remove all the screws indicated in the pictures.
  5. HP Pavilion dv4-4141us Fan Replacement: 步骤 5 中的图像 1,1
    • Use opening tool to separate the Key board and mouse pad.
    • It would be best to find a tool that is small enough to fit and start on the bottom at either corner and slide across lifting the panel up.
    • Be careful not to push too far underneath to not damage the interior and also it is advised to not bend or crack the plastic back cover.
  6. HP Pavilion dv4-4141us Fan Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to gently lift the white plastic flap and release the ribbon cable holding the keyboard in place.
  7. HP Pavilion dv4-4141us Fan Replacement: 步骤 7 中的图像 1,2 HP Pavilion dv4-4141us Fan Replacement: 步骤 7 中的图像 2,2
    • Use the spudger to lift up the flap and release the cable for both of these two separate components.
    • Be extra careful not to break these clips as they are fragile and are a part of the motherboard.
  8. HP Pavilion dv4-4141us Fan Replacement: 步骤 8 中的图像 1,1
    • Unclip the last wire holding the motherboard in place. To do this pull down on the wire in the direction of the arrow.
  9. HP Pavilion dv4-4141us Fan Replacement: 步骤 9 中的图像 1,2 HP Pavilion dv4-4141us Fan Replacement: 步骤 9 中的图像 2,2
    • Take out the mother board and flip it over so that you can access the fan.
    • Unscrew the two screws holding the fan in place.
  10. HP Pavilion dv4-4141us Fan Replacement: 步骤 10 中的图像 1,1
    • Release the fan from the motherboard by disconnecting the wire from the fan.
结论
另外一个人完成了本指南。
Vincent Gardner
于10/25/21注册
390 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 UMass Dartmouth, Team 2-3, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G3
3 名成员
创作了7篇指南
一条评论
Thanks! I was able to upgrade my Intel Core i3 2330m to a considerably more powerful core i5 2410m! The instructions were very easy to follow. This fixed my problem!
Sam Watson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 24
总计 306
