跳转到主内容
HP Pavilion dv2913cl WiFi receiver Replacement
你所需要的
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: 步骤 1 中的图像 1,1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: 步骤 2 中的图像 1,1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv2913cl WiFi receiver Replacement: 步骤 4 中的图像 2,2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
结论
Adam Braga
于10/24/16注册
230 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 134
