跳转到主内容
HP Pavilion dv2913cl Keyboard Replacement
你所需要的
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv2913cl Keyboard Replacement: 步骤 3 中的图像 2,2
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: 步骤 4 中的图像 1,1
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion dv2913cl Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv2913cl Keyboard Replacement: 步骤 6 中的图像 2,2
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
结论
另外一个人完成了本指南。
Adam Braga
于10/24/16注册
230 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G7
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 161
