跳转到主内容
HP Pavilion dv2700 Hard Drive Replacement
你所需要的
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: 步骤 4 中的图像 1,2 HP Pavilion dv2700 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
结论
2等其他人完成本指南。
Jared Opperman
于09/24/15注册
161 声望
撰写一个指南
团队
Texas Tech, Team 22-6, Rauch Fall 2015 Texas Tech, Team 22-6, Rauch Fall 2015 的会员
TTU-RAUCH-F15S22G6
3 名成员
创作了2篇指南
一条评论
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 22
总计 2,994
