跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv2700 Camera Module Replacement
你所需要的
  1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: 步骤 1 中的图像 1,1
    • Disconnect device from power source and power down.
    • Disconnect any other external devices.
  2. HP Pavilion dv2700 Camera Module Replacement: 步骤 2 中的图像 1,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 2 中的图像 2,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 2 中的图像 3,3
    • Flip the laptop over so that the bottom is facing upwards.
    • Use your index finger to push the battery latch.
    • Pivot the battery upward and lift it out of the socket to remove it.
  3. HP Pavilion dv2700 Camera Module Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop right side up.
    • Open it as wide as the hinge allows it to.
  4. HP Pavilion dv2700 Camera Module Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 4 中的图像 3,3
    • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
    • Remove the Phillips PM2.5×5.0 screws.
    • Remove the two rubber screw covers located at the bottom left and right of the bezel.
  5. HP Pavilion dv2700 Camera Module Replacement: 步骤 5 中的图像 1,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 5 中的图像 2,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 5 中的图像 3,3
    • Flex the inside edges of the left and right sides and the top edge of the display bezel.
    • Lift the bezel with your finger until it disengages from the display enclosure.
  6. HP Pavilion dv2700 Camera Module Replacement: 步骤 6 中的图像 1,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 6 中的图像 2,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 6 中的图像 3,3
    • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
    • Release the camera module assembly unit by simply pulling it out of the laptop.
  7. HP Pavilion dv2700 Camera Module Replacement: 步骤 7 中的图像 1,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 7 中的图像 2,3 HP Pavilion dv2700 Camera Module Replacement: 步骤 7 中的图像 3,3
    • Disconnect the camera module cable from the camera module itself by pulling it out.
    • Be careful not to break the camera module cable.
    • Turn the module upside down and remove the screws for the camera bracket.
    • Remove the camera module from the bracket.
结论
Kayaen Jardine
于07/05/20注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 668
