跳转到主内容
HP Pavilion dv2000 Wireless Card Replacement
你所需要的
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 1,2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 2,2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv2000 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: 步骤 3 中的图像 1,3 HP Pavilion dv2000 Wireless Card Replacement: 步骤 3 中的图像 2,3 HP Pavilion dv2000 Wireless Card Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    购买
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
结论
3等其他人完成本指南。
Erik Muniz
于09/09/14注册
820 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G3
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 2,180
