简介
This guide will help you replace the wireless card on you HP Pavilion dv2000.
你所需要的
Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
Lift up and remove the wireless card casing.
Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
Gently pull out your wireless card from its top side to remove it from its holding.
即将完成!
结论
3等其他人完成本指南。
