跳转到主内容
HP Pavilion dv2000 Keyboard Replacement
你所需要的
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Pavilion dv2000 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion dv2000 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv2000 Keyboard Replacement: 步骤 3 中的图像 2,2
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
结论
6等其他人完成本指南。
Erik Muniz
于09/09/14注册
820 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G3
3 名成员
创作了3篇指南
一条评论
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 2,754
