跳转到主内容
HP Pavilion dv2000 Hard Drive Replacement
你所需要的
  1. HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,2 HP Pavilion dv2000 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    购买
    • Flip your computer over, so that the underside of your computer is facing upward.
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate the hard drive casing on the bottom-right corner of your flipped computer.
    • Remove the two 3.8mm screws with your Phillips #00 Screwdriver and carefully lift up and remove the hard drive casing.
    • Screws on hard drive casing will remain in casing after being unscrewed.
  2. HP Pavilion dv2000 Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion dv2000 Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion dv2000 Hard Drive Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #000 Screwdriver
    $5.49
    购买
    • After you lift off the hard drive casing, using your Phillips #000 Screwdriver, remove the two 3.6mm screws located on the right side of the hard drive.
    • Using your fingers, carefully lift the lower right corner of your hard drive until it is removed from its housing.
结论
7等其他人完成本指南。
Erik Muniz
于09/09/14注册
820 声望
创作了3篇指南
团队
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G3
3 名成员
创作了3篇指南
一条评论
You didnt mention this HDD has a different SATA connector , I cant find it in the market, instead of plug in , this one is for pressing down only
tml215 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 23
总计 4,282
