跳转到主内容
HP Pavilion dv1000 Keyboard Replacement
你所需要的
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion dv1000 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: 步骤 4 中的图像 1,3 HP Pavilion dv1000 Keyboard Replacement: 步骤 4 中的图像 2,3 HP Pavilion dv1000 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion dv1000 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
结论
另外一个人完成了本指南。
Tyler Latour
于03/12/14注册
266 声望
创作了3篇指南
团队
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S6G7
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 1,586
