跳转到主内容
HP Pavilion dm4-2015dx Keyboard Replacement
你所需要的
  1. HP Pavilion dm4-2015dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Turn off the device, disconnect it from all power, and remove the battery.
    • Remove the two highlighted screws to release the memory cover.
  2. HP Pavilion dm4-2015dx Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion dm4-2015dx Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two highlighted screws to release the hardware cover.
    • Remove the two screws highlighted in the 2nd image to release the hard drive cover.
  3. HP Pavilion dm4-2015dx Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the screws (as shown in pic), these two screws secure the HP keyboard.
    • Use a flathead screwdriver to release the highlighted keyboard tabs with ease.
  4. HP Pavilion dm4-2015dx Keyboard Replacement: 步骤 4 中的图像 1,1
    • Turn the device right-side up and pull the keyboard frame upward along the top row of keys. There are Four (4) protruding male clips that engage along this top edge. Use a flathead screwdriver or similar tool to pry the keyboard from the frame.
    • Locate and remove the lockdown cable and unlock the keyboard cables. When prying the keyboard up, you will find resistance as a small 2 inch x 1/4 inch strip of double face tape is used to further hold the keyboard in place. (Depending upon the age of the laptop, it may require additional pulling strength to break the tapes bond.)
    • Slide out the keyboard cable and install a new HP Pavilion DM4 keyboard.
结论
2等其他人完成本指南。
Jacob Meloche
于10/20/16注册
597 声望
创作了4篇指南
团队
UMass Dartmouth, Team 6-1, Martin Fall 2016 UMass Dartmouth, Team 6-1, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 2,778
