跳转到主内容
HP Pavilion ZD7000 Wi-Fi Card Replacement
你所需要的
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 HP Pavilion ZD7000 Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
结论
3等其他人完成本指南。
Shantel
于04/20/10注册
545 声望
创作了6篇指南
团队
Cal Poly, Team 30-37, Garner Spring 2010 Cal Poly, Team 30-37, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G37
4 名成员
创作了6篇指南
2条评论
Can you upgrade the wifi card?
danoco - 回复
is there a replacement I can buy
Braeden Culp - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 5,436
