跳转到主内容
HP Pavilion Wave 600-a010 hard drive Replacement
你所需要的
  1. HP Pavilion Wave 600-a010 hard drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 2 中的图像 1,1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 4 中的图像 1,1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 5 中的图像 2,2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 6 中的图像 2,2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion Wave 600-a010 hard drive Replacement: 步骤 8 中的图像 2,2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
结论
5等其他人完成本指南。
2条评论
Why isn't there any information regarding cloning or transferring the original HDD and RECOVERY (D:) partition to the SSD. After my ssd upgrade I tried to use the recovery media and it would not work.. The portion or removal and replacing was pretty much spot on especially if you have done this type of thing before. (At least in my opinion)
CERB - 回复
Were you able to clone the HDD to your SSD? How about recovery? Also, is it possible and are there enough room for SSD and HDD? Please share your experience. Thank you!
thomastranrx - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 3,164
