跳转到主内容
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
你所需要的
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
    12- M2x4 screws to remove. And it helps to remove the screws holding the elbow because it releases the front plate at the top corners.
    Con Fran - 回复
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
结论
3等其他人完成本指南。
Robert Hemphill
于01/22/15注册
269 声望
创作了2篇指南
团队
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G22
4 名成员
创作了6篇指南
一条评论
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,656
