跳转到主内容
HP Pavilion Touchsmart 11z-e000 Fan Replacement
你所需要的
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: 步骤 2 中的图像 1,1
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 步骤 3 中的图像 1,1
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 步骤 4 中的图像 1,1
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 步骤 6 中的图像 1,1
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
结论
Nguyen
于01/22/15注册
295 声望
创作了2篇指南
团队
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 的会员
CPSU-MANESS-W15S21G22
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,049
