跳转到主内容
HP Pavilion Touchsmart 10-e010nr Battery Replacement
  1. HP Pavilion Touchsmart 10-e010nr Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off device and place with battery facing up.
    • Ensure that your hands are not wet, even if the laptop is off or dead.
  2. HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 2 中的图像 1,2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 2 中的图像 2,2
    • Push slider on left-hand side of device into unlocked position. This slider is not spring loaded so it should stay in position afterwards.
  3. HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 3 中的图像 1,2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 3 中的图像 2,2
    • Push in right-hand slider with your thumb and simultaneously apply slight pressure away from your body.
    • It may be helpful to keep your left thumb on the left slider and push with both thumbs.
  4. HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 4 中的图像 1,2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: 步骤 4 中的图像 2,2
    • Battery should easily separate from main device.
结论
Sean
于09/17/18注册
159 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 457
