跳转到主内容
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
你所需要的
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
结论
Justin Hurley
于01/14/19注册
1 声望
撰写一个指南
团队
IUPUI, Team S6-G6, Wilson Spring 2019 IUPUI, Team S6-G6, Wilson Spring 2019 的会员
IUPUI-WILSON-S19S6G6
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 356
