跳转到主内容
HP Pavilion TPN-C125 RAM Replacement
你所需要的
  1. HP Pavilion TPN-C125 RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Pavilion TPN-C125 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Flip the laptop over so the bottom is facing up and the external battery is at the top.
  2. HP Pavilion TPN-C125 RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion TPN-C125 RAM Replacement: 步骤 2 中的图像 2,2
    • Use your thumbs to slide the battery locks towards the center and pop the battery out.
  3. HP Pavilion TPN-C125 RAM Replacement: 步骤 3 中的图像 1,2 HP Pavilion TPN-C125 RAM Replacement: 步骤 3 中的图像 2,2
    • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
    • This will expose two Philips #00 10 mm screws required to remove the back plate.
    • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
  4. HP Pavilion TPN-C125 RAM Replacement: 步骤 4 中的图像 1,2 HP Pavilion TPN-C125 RAM Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
    • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
    • You will hear a "click" as you release the clips and remove it.
  5. HP Pavilion TPN-C125 RAM Replacement: 步骤 5 中的图像 1,3 HP Pavilion TPN-C125 RAM Replacement: 步骤 5 中的图像 2,3 HP Pavilion TPN-C125 RAM Replacement: 步骤 5 中的图像 3,3
    • The RAM sticks can be found in the bottom right section of the laptop.
    • Push both side arms holding the RAM stick in place outwards.
    • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
    • Slide the RAM sticks out of the socket gently.
  6. HP Pavilion TPN-C125 RAM Replacement: 步骤 6 中的图像 1,3 HP Pavilion TPN-C125 RAM Replacement: 步骤 6 中的图像 2,3 HP Pavilion TPN-C125 RAM Replacement: 步骤 6 中的图像 3,3
    • Carefully slide the new replacement RAM sticks into their slots.
    • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
    • Gently push the RAM sticks downward until the latches click into place to secure them.
结论
Cesar Gomez
于03/05/24注册
183 声望
撰写一个指南
团队
CSU Los Angeles, Team 7-10, Grodsky Spring 2024 CSU Los Angeles, Team 7-10, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S7G10
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 70
总计 169
