跳转到主内容
简介
By using the following tools and the following the steps below, you can simply remove your hard drive from your HP Pavilion Sleekbook and replace it with a new one.
  1. Open the laptop and locate the keyboard. Identify the borders of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard. Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
  2. Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
  3. Pop out the black frame found underneath the keyboard using the plastic opening tools. Once the frame is popped out continue to lift the frame gently. Once the frame is popped out continue to lift the frame gently.
    • Pop out the black frame found underneath the keyboard using the plastic opening tools.
    • Once the frame is popped out continue to lift the frame gently.
  4. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner. Locate and remove the silver hard drive cover in the bottom right corner.
    • Locate and remove the silver hard drive cover in the bottom right corner.
  5. Detach and remove the hard drive from the black plug located to the right of the hard drive.
    • Detach and remove the hard drive from the black plug located to the right of the hard drive.
结论
12等其他人完成本指南。
Rashed
于2015年01月13日注册
670 信誉积分
撰写一个指南
团队
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G3
4 名成员
创作了5篇指南
Fatto per il modello 15-b131el!!
Simone Milesi - 回复
This technician has left out several crucial steps for this repair several screws on the bottom and several underneath the keyboard before the laptop casing will come apart, common sense for a tech but a how-to should not leave these details out.
dloeper2391 - 回复
These instructions ruined my friends laptops. PLEASE do not post directions like this if you don’t know what you ‘re doing as folks like me will mistakenly assume that you do & attempt this and then damage cables. VERY, VERY careful folks! Cost me $200 for a replacement laptop.
Andre Bajew - 回复
If you do not remove the screws you will crack the keyboard and cover.
HometownComputers - 回复
WIll it support any SSD drive to upgrade from basic HDD?
Gajanan Thirumoolanathan - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 16
过去的30天: 49
总计 16,025
