跳转到主内容
简介
The removal and installation of the battery in this computer is very straightforward, requiring no additional tools other than your hands. This guide will demonstrate how to properly remove and replace the battery.
  1. Flip the laptop over and locate the release switches located at the back corners of the laptop. Flip the laptop over and locate the release switches located at the back corners of the laptop.
    • Flip the laptop over and locate the release switches located at the back corners of the laptop.
  2. Carefully slide the leftmost switch to the right, which is the unlock position, as shown by the orange unlock icon. Carefully slide the leftmost switch to the right, which is the unlock position, as shown by the orange unlock icon.
    • Carefully slide the leftmost switch to the right, which is the unlock position, as shown by the orange unlock icon.
  3. Slide the rightmost switch to the left, which will release the battery from the back of the laptop, enabling it to be pulled out. Carefully pull the battery out away from the laptop, disconnecting it completely. Carefully pull the battery out away from the laptop, disconnecting it completely.
    • Slide the rightmost switch to the left, which will release the battery from the back of the laptop, enabling it to be pulled out.
    • Carefully pull the battery out away from the laptop, disconnecting it completely.
结论
Now that you've successfully replaced the battery, restart your laptop and resume normal operation.
10等其他人完成本指南。
Jonathan
于2015年01月13日注册
755 信誉积分
创作了3篇指南
团队
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015 的会员
USFT-HICKMAN-W15S3G3
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 2,828
