跳转到主内容
HP Pavilion Sleekbook 15- b000 Fan
你所需要的
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: 步骤 1 中的图像 1,1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: 步骤 2 中的图像 1,1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: 步骤 3 中的图像 1,2 HP Pavilion Sleekbook 15- b000 Fan: 步骤 3 中的图像 2,2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: 步骤 4 中的图像 1,1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: 步骤 5 中的图像 1,1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: 步骤 6 中的图像 1,1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: 步骤 7 中的图像 1,1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: 步骤 8 中的图像 1,1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: 步骤 9 中的图像 1,1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: 步骤 10 中的图像 1,1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: 步骤 11 中的图像 1,1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: 步骤 12 中的图像 1,3 HP Pavilion Sleekbook 15- b000 Fan: 步骤 12 中的图像 2,3 HP Pavilion Sleekbook 15- b000 Fan: 步骤 12 中的图像 3,3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: 步骤 13 中的图像 1,1
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: 步骤 14 中的图像 1,1
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: 步骤 15 中的图像 1,1
    • Remove fan.
结论
Sam Barkley
于02/13/18注册
983 声望
创作了8篇指南
团队
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 的会员
USFT-CHENG-S18S11G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 365
