简介
In this guide, you will learn how to replace your HP Pavilion Sleekbook's screen.
你所需要的
Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
另外一个人完成了本指南。
