简介
In this guide, you will learn how to replace your HP pavilion Sleekbook's Hard Disk Drive (HDD).
  1. Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    • Carefully pull the battery away from the device.
    • Using a Phillips #0 screwdriver, unscrew all eight of the screws.
    • Using a plastic opening tool, pry up on the upper edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected it.
    • To disconnect the wire, pry up on the latch holding it in its socket.
    • Flip the laptop back over.
    • Using a plastic or metal spudger, carefully pry the top and bottom halves of the case appart.
    • Don't push the metal spudger in too far or you might damage the laptops internal components.
    • Do not pull the halves apart yet as there are still wires attaching them together.
    • Disconnect the touch pad wire by flipping the small black lever using a plastic opening tool.
    • Unscrew the small circuit board underneath the power button.
    • Remove the circuit board by pulling up and away on the plastic tab.
    • Pull the top half of the plastic case off of the laptop.
    • Remove all seven of the screws using a Phillips #0 screwdriver and pull the plate off the motherboard.
    • There is double sided tape holding the plate down, as well as the screws. Sufficient force will be required to remove the plate.
    • Remove the USB wire which runs over the top of the hard drive.
    • The wire is stuck to the hard drive with double sided tape.
    • Remove the wire by carefully pulling towards the USB connector on the left hand side of the laptop.
    • Remove the four screws securing the hard drive to the motherboard.
    • Disconnect the hard drive cable by gently pulling it away from the hard drive.
结论
另外一个人完成了本指南。
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 18
总计 150
