跳转到主内容
简介
This guide shows how to disassemble the HP Pavilion Sleekbook 14-b013cl in order to replace the cooling fan.
  1. Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon). Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. Carefully pull the battery away from the device. Carefully pull the battery away from the device.
    • Carefully pull the battery away from the device.
  4. Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. Using a plastic opening tool, pry up along the edge of the keyboard. There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected. There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. To disconnect the wire, pry up on the latch connecting it to the motherboard. To disconnect the wire, pry up on the latch connecting it to the motherboard. To disconnect the wire, pry up on the latch connecting it to the motherboard.
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop. Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far. Do not completely pull the halves apart yet because there are still wires holding them together.
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. Disconnect the touch pad wire by flipping the black lever with a plastic spudger. Disconnect the touch pad wire by flipping the black lever with a plastic spudger. Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. Unscrew the circuit board underneath the power button. Remove this circuit board by pulling up and away on the plastic tab.
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board. Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate. Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver. Using a plastic opening tool, remove the power cable for the fan.
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
结论
另外一个人完成了本指南。
Josh Svik
于2018年04月10日注册
281 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 202
