跳转到主内容
简介
This guide should be used if you have experienced issues with the battery, such as the battery not holding a charge or the computer only turning on while plugged in. Make sure that the device is fully powered off before attempting to remove the battery. No tools are required for this guide.
  1. Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon). Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery. Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. Carefully pull the battery away from the device. Carefully pull the battery away from the device.
    • Carefully pull the battery away from the device.
结论
Place your new battery into the slot you just removed the old battery out of, and follow the steps in reverse order to accomplish this.
另外一个人完成了本指南。
Duncan Steele
于2018年04月10日注册
308 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 277
