跳转到主内容
HP Pavilion N3350 RAM Replacement
你所需要的
  1. HP Pavilion N3350 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Locate the RAM on the bottom side of the laptop, the cover is secured by a 6 millimeter screw. Remove this with a Philips #1 screwdriver.
  2. HP Pavilion N3350 RAM Replacement: 步骤 2 中的图像 1,1
    • Underneath are the RAM boards. They are secured by two plastic clips each. Locate these to continue removal.
  3. HP Pavilion N3350 RAM Replacement: 步骤 3 中的图像 1,1
    • Place your thumbs on two of the clips securing one board. Push outwards on the clips. This should pop the board up.
  4. HP Pavilion N3350 RAM Replacement: 步骤 4 中的图像 1,1
    • Repeat on second board. When both are released, they should appear as they do in the picture.
  5. HP Pavilion N3350 RAM Replacement: 步骤 5 中的图像 1,1
    • The RAM should be easily removed once released from the plastic clips.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G8
3 名成员
创作了8篇指南
一条评论
Windows 98 Product Key?
Dudefoxlive - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 140
