跳转到主内容
HP Pavilion N3350 Optical Drive Replacement
你所需要的
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: 步骤 2 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 步骤 4 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 步骤 4 中的图像 2,2
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: 步骤 6 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 6 中的图像 2,2
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: 步骤 7 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 7 中的图像 2,2
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: 步骤 8 中的图像 1,2 HP Pavilion N3350 Optical Drive Replacement: 步骤 8 中的图像 2,2
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
结论
另外一个人完成了本指南。
Lyndon Davis
于03/19/18注册
124 声望
撰写一个指南
团队
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G8
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 7
总计 243
