跳转到主内容
HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement
你所需要的
  1. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 2 中的图像 2,2
    • Using the 1.5 Phillips #1 screwdriver, loosen the 7 screws.
  3. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 3 中的图像 3,3
    • Insert the metal opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case.
    • Remove the back case.
    • When removing the back plate, use caution, removing slowly in order to not break the clips.
  4. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 4 中的图像 1,3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 4 中的图像 2,3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 4 中的图像 3,3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • With your fingers, push on the Ram stick until the metal arms are not holding the stick.
    • The RAM will pop up by a few millimeters up.
    • Remove it by pulling straight towards you and not a angle so you don't damage the socket.
  5. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 5 中的图像 1,2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: 步骤 5 中的图像 2,2
    • Slide the RAM stick out from the memory module slot.
    • Repeat for the RAM stick located below. This computer had RAM in the slot below.
结论
另外一个人完成了本指南。
Anthony Padilla
于10/30/23注册
121 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-17, Kershman Fall 2023 CSU Los Angeles, Team 5-17, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S5G17
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 51
总计 178
