跳转到主内容
HP Pavilion G7-2289wm RAM Replacement
你所需要的
  1. HP Pavilion G7-2289wm RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Loosen the screw that secures the service cover.
    • Pull the service cover towards you to remove it.
  3. HP Pavilion G7-2289wm RAM Replacement: 步骤 3 中的图像 1,1
    • Unlock the tabs on each side of the ram module. (this lifts the ram module up)
  4. HP Pavilion G7-2289wm RAM Replacement: 步骤 4 中的图像 1,1
    • Remove the ram module by pulling it gently away from the slot.
结论
Ryson Smith
于03/19/18注册
636 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 124
