跳转到主内容
HP Pavilion G7-2289wm Hard Drive Replacement
你所需要的
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
结论
Ryson Smith
于03/19/18注册
636 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 194
