跳转到主内容
HP Pavilion G7-2289wm Optical Drive Replacement
你所需要的
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 1,1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: 步骤 3 中的图像 1,2 HP Pavilion G7-2289wm Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
结论
Ryson Smith
于03/19/18注册
636 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 273
