跳转到主内容
HP Pavilion G7-2235DX Screen Replacement
你所需要的
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: 步骤 2 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: 步骤 3 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: 步骤 4 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 4 中的图像 2,2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: 步骤 5 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 5 中的图像 2,2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: 步骤 6 中的图像 1,1
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: 步骤 7 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 7 中的图像 2,2
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: 步骤 8 中的图像 1,2 HP Pavilion G7-2235DX Screen Replacement: 步骤 8 中的图像 2,2
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
结论
2等其他人完成本指南。
Bre'Anna Sanders
于10/11/16注册
113 声望
创作了2篇指南
团队
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G7
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 452
