跳转到主内容
HP Pavilion G60-630US Power Button Replacement
你所需要的
  1. HP Pavilion G60-630US Power Button Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the laptop is powered off and unplugged first.
    • Turn your laptop over so the bottom is facing up.
    • Locate the battery latch and slide the latch switch all the way to the left.
    • The latch will lock and stay in place.
  2. HP Pavilion G60-630US Power Button Replacement: 步骤 2 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement: 步骤 2 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement: 步骤 2 中的图像 3,3
    • Carefully lift the battery out and away from the laptop.
  3. HP Pavilion G60-630US Power Button Replacement, Power Button: 步骤 3 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement, Power Button: 步骤 3 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement, Power Button: 步骤 3 中的图像 3,3
    • Open the laptop normally.
    • Using your fingers (or a spudger if needed), loosen the silver cover surrounding the keyboard.
    • You will not be able to fully remove the keyboard/silver border all the way until the next step.
  4. HP Pavilion G60-630US Power Button Replacement: 步骤 4 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement: 步骤 4 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement: 步骤 4 中的图像 3,3
    • Carefully place your hands underneath the now loosened keyboard and locate the ribbon keeping the keyboard connected to the laptop.
    • Locate the tabs keeping the ribbon in place.
    • Gently push the tabs inward to release the ribbon and to detach the keyboard.
    • Carefully remove the keyboard and place it off to the side.
    • The silver border and the power button will still be connected by a different ribbon.
  5. HP Pavilion G60-630US Power Button Replacement: 步骤 5 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement: 步骤 5 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement: 步骤 5 中的图像 3,3
    • Locate the ribbon keeping the power button attached to the laptop.
    • Push the tab attaching the ribbon to the laptop to detach the silver border and the power button.
  6. HP Pavilion G60-630US Power Button Replacement: 步骤 6 中的图像 1,3 HP Pavilion G60-630US Power Button Replacement: 步骤 6 中的图像 2,3 HP Pavilion G60-630US Power Button Replacement: 步骤 6 中的图像 3,3
    • If you are looking at this in the HP Pavilion G60-630US Screen Replacement Guide, ignore this step
    • Flip the silver border over to expose the underside of the power bar.
    • Unscrew the 4 screws keeping the power bar in place. Place the screws off the the side.
    • Carefully remove the power bar.
结论
[deleted]
于10/02/17注册
213 声望
创作了2篇指南
一条评论
You have neglected to speak about removal of 5 screws from the bottom of the laptop! 3 inside the battery compartment and 2 on the corners of the laptop. Removal of these allow removal of the bezel and keyboard. Failure to remove these screws will cause damage to the keyboard and bezel!
Dave - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 31
总计 2,201
