简介
The power button may not be turning on the laptop. There may be a disconnect of wires or the power bar chip may be defective. If the power button is not working or broken and it needs to be replaced, the following steps show how to replace the components that make the power button work.
你所需要的
Turn your laptop over so the bottom is facing up.
Locate the battery latch and slide the latch switch all the way to the left.
Open the laptop normally.
Using your fingers (or a spudger if needed), loosen the silver cover surrounding the keyboard.
Carefully place your hands underneath the now loosened keyboard and locate the ribbon keeping the keyboard connected to the laptop.
Locate the tabs keeping the ribbon in place.
Gently push the tabs inward to release the ribbon and to detach the keyboard.
Carefully remove the keyboard and place it off to the side.
