跳转到主内容
HP Pavilion G60-235DX Keyboard Replacement
你所需要的
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: 步骤 1 中的图像 1,2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: 步骤 2 中的图像 1,3 HP Pavilion G60-235DX Keyboard  Replacement: 步骤 2 中的图像 2,3 HP Pavilion G60-235DX Keyboard  Replacement: 步骤 2 中的图像 3,3
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: 步骤 3 中的图像 1,1
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
结论
Gilbert Han
于01/24/17注册
241 声望
创作了2篇指南
团队
Cal Poly, Team 10-5, Banghart Winter 2017 Cal Poly, Team 10-5, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 481
