跳转到主内容
HP Pavilion G6-2249wm screen Replacement
你所需要的
  1. HP Pavilion G6-2249wm screen Replacement, Battery removal: 步骤 1 中的图像 1,1
    • Make sure the computer is shut off.
    • When you know that is shut off you may remove the battery
  2. HP Pavilion G6-2249wm screen Replacement, Begin screen removal: 步骤 2 中的图像 1,1
    • Remove the little pieces of black sticky tape covering the screws that need to be removed in each lower corner
    needs*******
    wyatt - 回复
  3. HP Pavilion G6-2249wm screen Replacement, screw removal: 步骤 3 中的图像 1,1
    • After the little black sticky tape is removed the two little screws at the lower corners of the screen need to be removed (place the screws on a little piece of tape).
    is gone******
    wyatt - 回复
  4. HP Pavilion G6-2249wm screen Replacement, screen cover removal: 步骤 4 中的图像 1,2 HP Pavilion G6-2249wm screen Replacement, screen cover removal: 步骤 4 中的图像 2,2
    • After removing the screws, pop out the plastic protector (can be done with your fingers).
    • Start at one corner and run your finger under the plastic and it will pop out.
  5. HP Pavilion G6-2249wm screen Replacement, screen screw removal: 步骤 5 中的图像 1,1
    • On each side of the screen there are two little screws, one on top and one on bottom.
    • All four of the screws need to be removed (place the screws on a little piece of tape so they won't be lost).
  6. HP Pavilion G6-2249wm screen Replacement, screen removal: 步骤 6 中的图像 1,1
    • Once the screws are out, remove the screen and lay it on your keyboard.
  7. HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 步骤 7 中的图像 1,3 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 步骤 7 中的图像 2,3 HP Pavilion G6-2249wm screen Replacement, digital attachment removal: 步骤 7 中的图像 3,3
    • Once the screen is laying down you will see a connector on the back of it.
    • Pull the sticker off which pulls the connector with it.
  8. HP Pavilion G6-2249wm screen Replacement, Reconnecting the screen: 步骤 8 中的图像 1,1
    • After the new screen has arrived, reconnect the little connecter strip.
  9. HP Pavilion G6-2249wm screen Replacement, Replacing the screws: 步骤 9 中的图像 1,2 HP Pavilion G6-2249wm screen Replacement, Replacing the screws: 步骤 9 中的图像 2,2
    • After the connecter has been connected place the screen back into its place.
    • Once the screen is in place put in the four little screws that go in each corner of the screen.
  10. HP Pavilion G6-2249wm screen Replacement, black cover placement: 步骤 10 中的图像 1,2 HP Pavilion G6-2249wm screen Replacement, black cover placement: 步骤 10 中的图像 2,2
    • After the screen is screwed in place the black plastic cover back over the screen.
    • Once the black over is in place start clicking the clips back into place by just pressing with your fingers.
  11. HP Pavilion G6-2249wm screen Replacement, Screwing the cover in place: 步骤 11 中的图像 1,1
    • After the black cover is in place start to but the two little screws back in the two button corners
  12. HP Pavilion G6-2249wm screen Replacement, Sticker placement: 步骤 12 中的图像 1,1
    • After the screws are in place the little black sticker over the screws.
  13. HP Pavilion G6-2249wm screen Replacement, Placing the battery: 步骤 13 中的图像 1,1
    • After the screen is in and everything is tight and in place you may but the battery back in.
  14. HP Pavilion G6-2249wm screen Replacement, Turning on the computer: 步骤 14 中的图像 1,1
    • Once the battery is in place you may turn is it on and watch your screen come back to life.
结论
9等其他人完成本指南。
hunter
于02/17/15注册
294 声望
撰写一个指南
团队
Vegas Room H9 Vegas Room H9 的会员
Community
13 名成员
创作了17篇指南
一条评论
Good guide. Easiest screen replacement ever.
I’m concerned about your poor little knuckles.
Jim Buchholz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,135
