简介
I'm going to replace the broken screen because my dad is not the best with technology and punched the screen.
你所需要的
Make sure the computer is shut off.
When you know that is shut off you may remove the battery
Remove the little pieces of black sticky tape covering the screws that need to be removed in each lower corner
After the little black sticky tape is removed the two little screws at the lower corners of the screen need to be removed (place the screws on a little piece of tape).
After removing the screws, pop out the plastic protector (can be done with your fingers).
Start at one corner and run your finger under the plastic and it will pop out.
On each side of the screen there are two little screws, one on top and one on bottom.
All four of the screws need to be removed (place the screws on a little piece of tape so they won't be lost).
Once the screen is laying down you will see a connector on the back of it.
Pull the sticker off which pulls the connector with it.
After the new screen has arrived, reconnect the little connecter strip.
After the connecter has been connected place the screen back into its place.
Once the screen is in place put in the four little screws that go in each corner of the screen.
After the screen is screwed in place the black plastic cover back over the screen.
Once the black over is in place start clicking the clips back into place by just pressing with your fingers.
After the black cover is in place start to but the two little screws back in the two button corners
After the screen is in and everything is tight and in place you may but the battery back in.
Once the battery is in place you may turn is it on and watch your screen come back to life.
9等其他人完成本指南。
一条评论
Good guide. Easiest screen replacement ever.
I’m concerned about your poor little knuckles.
