跳转到主内容
HP Pavilion G6-1d16dx Wireless Card Replacement
你所需要的
  1. HP Pavilion G6-1d16dx Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,2 HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 2,2
    • Unscrew the two captive screws using the Phillips #000 screwdriver.
    • The screws will not come all the way out; stop when you hear them click.
    • Unsnap the protective cover off of the device.
    • Locate the wireless card.
  5. HP Pavilion G6-1d16dx Wireless Card Replacement: 步骤 5 中的图像 1,2 HP Pavilion G6-1d16dx Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Remove the two screws located on the corners of the wireless card, using the Phillips #000 screwdriver.
    • Slide the Wi-Fi card out of the socket.
  6. HP Pavilion G6-1d16dx Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Using your fingers, unsnap the coaxial cable wires from the wireless card.
    • Connect them to the new card based on the attachment points.
    • These points are indicated by numbered tabs. For example, wire #1 connects to #1 on the wireless card.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 17
总计 1,417
