跳转到主内容
HP Pavilion G6-1d16dx Hard Drive Replacement
  1. HP Pavilion G6-1d16dx Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
    • Unscrew the two silver screws holding the protective cover in place.
    • The screws do not detach from the cover.
    • Remove Cover by lifting the edge along the battery compartment.
    • Slide the hard drive towards the empty gap, lift up on the hard drive, and remove it.
    • If the replacement hard drive lacks a rubber case- remove the rubber case that is around the old hard drive, and place it over the new hard drive.
    • Re-insert the hard drive, and slide it back into place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 91
