跳转到主内容
HP Pavilion DV9700 RAM Replacement
你所需要的
  1. HP Pavilion DV9700 RAM Replacement, RAM: 步骤 1 中的图像 1,2 HP Pavilion DV9700 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: 步骤 2 中的图像 1,2 HP Pavilion DV9700 RAM Replacement: 步骤 2 中的图像 2,2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: 步骤 3 中的图像 1,3 HP Pavilion DV9700 RAM Replacement: 步骤 3 中的图像 2,3 HP Pavilion DV9700 RAM Replacement: 步骤 3 中的图像 3,3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: 步骤 4 中的图像 1,3 HP Pavilion DV9700 RAM Replacement: 步骤 4 中的图像 2,3 HP Pavilion DV9700 RAM Replacement: 步骤 4 中的图像 3,3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
结论
Max Shangraw
于03/19/18注册
507 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 771
