跳转到主内容
HP Pavilion DV9700 Optical Drive Replacement
你所需要的
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: 步骤 1 中的图像 1,3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: 步骤 1 中的图像 2,3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: 步骤 1 中的图像 3,3
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: 步骤 2 中的图像 1,3 HP Pavilion DV9700 Optical Drive  Replacement: 步骤 2 中的图像 2,3 HP Pavilion DV9700 Optical Drive  Replacement: 步骤 2 中的图像 3,3
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
结论
另外一个人完成了本指南。
Max Shangraw
于03/19/18注册
507 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 358
